05-08-2007
It depends... a properly packed gland should really not be leaking when the shaft is not turning. If yours is, then you need to tighten up on the packing gland nut a bit.
If that doesn't help, you will probably need to re-pack the gland. Traditional flax-based packing materials aren't as good as the newer Gore-tex based packing materials, which will leak less, and are lower maintenance. One of the guys on this site did a nice photograph laden walkthrough of the whole proces, which you can find if you do a search.
Edit: Found the link to the photo tutorial. LINK.
