05-08-2007
Mike-
If you're going to have to cut and pull the packing seal housing, I would definitely haul the boat out of the water for the job. The snot like substance is likely packing seal grease mixed well with water. Unfortunately, if the seal housing is really seized...then I think you're going ot have to pull the prop shaft.
While you're at this, you should probably replace the cutlass bearing as well.
