Patching water tank? - Page 2 - SailNet Community
post #11 of 11 Old 01-03-2008
I have repaired leaking plastic fuel tanks with the expandable plugs that you can get at the hardware,you must first drill a clean hole through the old one then insert the plug and tighten the machine screw to expand the plug.I would replace the plated screw with stainless.(note)will only work with a punched hole and not a crack line.Good luck.Bill NC
deerenick is offline
'68 M34 Water Tank Fill Hose Question dancrosswis Morgan 0 04-01-2006 03:07 PM
Water, Water Everywhere Tania Aebi Cruising Articles 0 06-14-2004 09:00 PM
