05-09-2007
The only precaution I would give you is to make sure that the Y-valve leg that leads from the holding tank to the Whale gusher pump is pointed down towards the holding tank, not towards the Gusher pump as you have in the drawing, and that it is mounted slightly higher than the PVC Y. That way, the sewage will drain from the valve back into the holding tank, rather than sitting in the valve and hose and causing a stench.
