Throttle tension - SailNet Community
post #1 of 2 Old 05-11-2007 Thread Starter
Space cadet
Jotun's Avatar
Throttle tension
For some strange reason, there is tension on the throttle of my I/D that causes it to fall back to about 1500 rpms when I push it past that mark. It's fine at slower rpms--no noticeable tension or movement. Any thoughts?
Jotun is offline
post #2 of 2 Old 05-12-2007
sounds like a little engine vibration might be causing it. Mine did it at high speeds. I took the spring on the engine lever and unhooked it so there was no return. I doubt the sping will do a thing even if the cable breaks.
P424 is offline
Motor Throttle Scubado Gear & Maintenance 0 05-19-2004 03:46 PM
Throttle Lever Tension jnj Gear & Maintenance 0 10-25-2002 03:32 AM
Rig Tension Dan Dickison Racing Articles 0 06-24-2002 09:00 PM
Mainsail Controls for Performance, Part Two Dan Dickison Gear and Maintenance Articles 0 02-27-2002 08:00 PM
Mainsail Controls for Performance, Part Two Dan Dickison Racing Articles 0 02-27-2002 08:00 PM
