Blogs
User Name
Old 05-13-2007
T37Chef's Avatar
T37Chef T37Chef is offline
Boat Show Sucker
T37Chef will become famous soon enough
Question Flushing Raw Water system? Barnacle Buster
Because taking off my heat exchanger requires the removal of the exhaust manifold (dont ask)...PITA!!! I found this product from TRAC Ecological Marine Products. It is also featured in this issue of Practical Sailor.
Has anyone used this product and what were your results? Did you use a recirculating unit or just let it sit?
Thanks
Ignore Power: I'm ignoring them
To get the most from Sailnet, follow the link in TheFrog's signature
Old 05-17-2007
T37Chef's Avatar
Boat Show Sucker
I have purchased it so we'll see how it does.
Old 05-17-2007
RichH RichH is offline
RichH is on a distinguished road
Ive use similar organic acid commercial boiler descalers both in industry and on my boat with excellent results. Other products were: Marsolve & Rydlyme.
Such descalers will easily remove the scale but not the base metal ... important since it will not remove the protective (blue/black) ferrous oxide coatings that form on cast iron, etc. Inorganic acids (Muriatic, etc.) will dissolve those ferrous layers and promote the destructive ferric (red) rust.
I find all of these products invaluable especially in descaling exhaust manifolds where the deposition of calcium carbonate to be the 'worst' in a marine engine ... and since it doesnt attack the base metal, retards the eventual manifold 'pinholes' that one gets when using Muriatic, etc. .
Small volume recirculation will insure complete scale removal, especially in those areas that have a high buildup .... preferred; but; is not absolutely necessary.
Old 05-17-2007
T37Chef's Avatar
Boat Show Sucker
Thanks RichH,
So the alternative to recirculating is to follow similar procedure as if you were winterizing...correct?
I don't want to purchase a recirculating system, but may try making my own from an old water pump left on the boat...should work?
Old 05-17-2007
Cruisingdad's Avatar
Cruisingdad Cruisingdad is offline
Moderator
Cruisingdad has a spectacular aura aboutCruisingdad has a spectacular aura about
T37,
How did it work??
- CD
Sailnet Moderator
Catalina 400 Technical Editor
Old 05-17-2007
T37Chef's Avatar
Boat Show Sucker
Haven't done it yet...hopefully this weekend
Old 05-17-2007
Freesail99's Avatar
Freesail99 Freesail99 is online now
Freesail99 will become famous soon enough
I spoke with a local marina at the Strickly Sail Show in Philly about a simular thing. They offered a service where they flushed diesel engines with a product just like this one. They claimed that after flushing your diesel it should run a good deal cooler. I plan on making an appointment with them later this summer.
S/V Scheherazade
Tony Orlando stand in and Burt Reynold's stunt double.
Old 05-17-2007
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
The MSDS says it is phosphoric acid. The active ingredient in Naval Jelly and most common rust removers, among other things. "Organic" as in "organic chemistry" not "organic foods".
Well, sure, that ought to work. Probably can buy phosphoric acid in some hardware or masonry supplies, too.
Old 05-17-2007
Moderator
Hello,
Quit gettin' technical. Caant a guy make a buck??
- CD
Sailnet Moderator
Old 05-17-2007
CD, I'm all for anyone making a buck any way they can.
I just have no tolerance for the newfangled "We're gonna make our money by MARKETING!!" business. Kids who think they need to drink bottled water from school vending machines...because the water fountain is too declasse?
Nah, not for me. Hey, if they are selling the stuff for the same price as phosphoric acid--I'm all in favor of it. Other than that......
Display Modes
vB code is On
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 06:11 PM
Water, Water Everywhere Tania Aebi Cruising Articles 0 06-14-2004 08:00 PM
Watermakers Don Casey Miscellaneous 0 02-01-2004 07:00 PM
Refrigeration—Part II Selecting a System Tom Wood Gear and Maintenance Articles 0 05-19-2003 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
