Old 05-13-2007
Gulfislander's Avatar
Gulfislander is on a distinguished road
Changing Halyard
Hi All,
I am looking at changing the main halyard on my Niagara 31. The halyard is internal. I've never done this before so I'm looking for advice on the best way to change it.
  #2
Old 05-13-2007
Gary M's Avatar
Gary M is on a distinguished road
Use a messenger line
Generaly you just get a lighter line and attached it at the tail. I use duct tape to join them but sewing it is more secure. Then you pull the business end out from the mast head and the messenger line will follow.
Once you have the old haliyard out detach the messenger line and reattach to the tail of the new line. Then pull the messenger line out at the exit in the mast and the new halyard will go up and into the mast head. Once it is through at the exit point you are all done.
PS nice boat.
  #3
Old 05-13-2007
SteveSouthwood is on a distinguished road
I recently changed my Halyard using a trick I think I saw in Cruising World. The first thing I did was to open out a paperclip so it looked like an elongated S. Then I threaded one end through the end of my old halyard where I had cut off the shackle. The other end of the paperclip was threaded through the far end of my new halyard. I then taped it all up. All I then had to do was pull the new halyard up and through the mast using my old. Worked a treat.
Steve
on the web
  #4
Old 05-13-2007
Gary M's Avatar
That is a good idea but you do not have to cut off your shackle just attach it to the tail. Your new halyard probably has a shackle already on it so you need to work at the other end.
  #5
Old 05-13-2007
Quickstep192 is on a distinguished road
I did mine recently. Both the new halyard and the old halyard were rope halyards, not wire-rope. Also, both were braid on braid lines. On one, I milked back some of the cover and cut off the core. On the other, I cut the cover back. I then shoved the exposed core into the cover of the one that I removed the core. I then sewed them together and put a pies of tape around the frayed part. I then pulled the new halyard in using the old halyard. This was probably overkill, but I REALLY didn't want to lose the halyard on the way through.
  #6
Old 05-13-2007
I cut off the old shackle so it could be attached to the new halyard. Saved me buying a new one. I'm not (yet) up to doing this myself so the store did it.
on the web
  #7
Old 05-13-2007
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
If you want to read more than ever care to know about every nuance of this topic, do a search on it. It's been covered in at least two recent threads. I'm an advocate of using duct tape to join the new with the old. works like a charm and has never failed me. Two weeks ago I used that method again to replace the reefing lines in my boom and despite more than expected tension in the process, the tape did the job.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
  #8
Old 05-13-2007
Thanks, I will try the paperclip and duct tape.
You may post attachments
You may edit your posts
Tale of the stuck halyard wlcoxe O'Day 0 08-23-2006 04:45 PM
Another lost halyard... pluscard Gear & Maintenance 13 06-26-2006 05:40 PM
halyard working load Randolph Bertin Learning to Sail 1 10-27-2003 11:12 PM
How to retrieve a halyard from masthead??? gwp General Discussion (sailing related) 8 05-29-2003 05:10 AM
Rereaving the Main Halyard Dan Dickison Racing Articles 0 02-11-2002 07:00 PM
SEO by vBSEO 3.6.1
