Old 05-14-2007
c2cSailor's Avatar
c2csailor
c2cSailor is on a distinguished road
Send a message via Yahoo to c2cSailor Send a message via Skype™ to c2cSailor
Question Draining sediment from RACOR- need to bleed engine?
I am a first time boat owner (Catalina 27) who has an older RACOR model 200FG with the clear bowl at the bottom. I can see quite a bit of sediment that needs to be drained. If I loosen/depress the nipple and drain the gunk, will air be introduced to the filter housing? Can I just fill the filter with fresh diesel without having to bleed? I have a Universal Model M-18 (14hp) that I'm sure is not self bleeding like the new Westerbekes.
Guess I have a little stage fright with having to bleed my engine for the first time if in fact I will need to. I guess my filter is about the same height as my fuel tank but I think the end of the fuel pick up tube is below the lowest level of the fuel filter drain.
Tim Haibach
Boatless
Texas City, TX
Old 05-14-2007
Pamlicotraveler's Avatar
Pamlicotraveler is on a distinguished road
Just open the top and bleed it via the nipple then pour enough diesel into the bowl to refill. You should change the filter at the same time though...No air should get in.
The next best thing
To playing and winning is playing and losing.
Robert Lee Castleman
Old 05-14-2007
Even if a little air gets in...IMHO it is better that you learn to bleed the fuel system now, rather than trying to figure it out in the middle of a storm, with the boat blowing down on a lee shore line... BTW, I generally have new owners mark the various screws that you need to bleed the diesel fuel system with a neon or or other brightly colored paint. That way, in an emergency, you can find them easily and quickly.
Old 05-14-2007
capttb is on a distinguished road
In a "new, used" boat if there's enough sediment to disturb you in the bowl I'd change the filter, and try to get as much fresh fuel as possible into the tank. The fuel in the tank now must be a little old and you are going to need to keep an eye on the amount of sediment that collects until you are able to run for 100 hrs. or so with no crap collecting in the bowl. Bleeding the air is pretty easy usually and as dog remarked it can be a REALLY important skill.
Old 05-15-2007
Omatako's Avatar
Omatako will become famous soon enough
If the worst comes to the worst, normally there will be a bleed screw on the back end of the injector pump where the air can be bled out before it gets into the pump or injector lines.
I don't know if your setup has a lift pump on the engine but if it does (normal)and the bleed screw referred to above is easily found then bleeding the air out should be simple.
Andre
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
