- Quick Menu
05-14-2007
I'd rather be sailing
12v Fans - Quiet but strong?
Does anyone have any suggestions on good 12v fans (with cages or protection around them)? I'm looking for the strong and silent type
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
05-14-2007
Hella - Mini Jet fans have worked well for me over the years.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
05-14-2007
On Blocks
Depending what you are using them for, try PC cooling fans. Believe it or not, they move a considerable amount of air and are very quiet, and very cheap (used). Not sure about long term durability though.
05-14-2007
"Muffin" fans
I agree. Commonly called muffin fans, they are readily available at electronic surplus outlets. If you want new, try a place like Fry's.
Gil
s/v Truthsayer
05-14-2007
Purveyor of Fine Ideas
What you're looking for are CPU case fans. They're easy to mount and wire up.
I would recommend buying them online, as you'll pay much less for them. For example, one of my favorite sites, Newegg.com has them starting around $2, or with a safety cage for around $10. Amazon.com also carries them.
Computer Case Fans, Case Fans, 4 Pin Case Fans, 70mm Case Fan at Newegg.com
If you like the instant gratification of driving to a place, plopping down cash, and leaving with your goods in hand, then try your local tech super center like Best Buy, CompUSA, Fry's, Circuit City or MicroCenter. Even Staples and Office Depot often carry CPU case fans.
05-14-2007
Do these CPU case fans, move air ? I saw a couple at the boat shows, about $50.00 but you knew it was a fan.
S/V Scheherazade
I had a dream, I was sailing, I was happy, I was even smiling. Then I looked down and saw that I was on a multi-hull and woke up suddenly in a cold sweat. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
05-14-2007
They make them in various sizes, with the larger 120 mm fans being quieter and moving more air than the smaller ones. I used some of the 40 mm fans for cooling the nav console/electrical panel on my friend's boat.
05-14-2007
I assumed that the 12 V fans were for cooling off people, at least that's what I was thinking about.
S/V Scheherazade
05-14-2007
yeah, case fans move a tremendous amount of air for their size.
If you ever have one fail in your computer, and get a glimpse of the mound of melted-together computer components you'll be replacing, then you'll fully appreciate how much air they move.
To cool a boat may take two or three of them, but at $10 a pop, thats a bargain at twice the price.
05-14-2007
You can use them to move air around the cabin to cool people, but the smaller ones are great for cooling or ventilating lockers, which can help prevent mold/mildew problems and in the case of equipment lockers prolong the life of the equipment.
| Thread Tools |
Search this Thread |
