ray marine vs furuno - SailNet Community
post #1 of 6 Old 02-05-2002 Thread Starter
does anyone have first hand experience with regard to furuno chart plotter vs a ray marine (raytheon) chart plotter. and which one is better?
thanks
eric
kimberlite is offline
post #2 of 6 Old 02-05-2002
Furuno is an excellent unit however it tends to take a while to get used too--in other words it is not user friendly whereas Raytheon is easier to use and is more intuitive. Furuno has more bells and whistles and probably has a much greater appeal amongst professional mariners. I spent a lot of time comparing the units and talking to both installers and users. For the money (maybe a tad more) you can''t go wrong with a Northstar unit. I also considered the new Garmin 2010 which has a very large 10'' screen and is in color and is probably the best buy on the market today. The only problem is that they use a proprietary charting product so you can''t use any of the other modules ieNavionics etc. so you are sort of stuck but it is an amazing chartplotter. At the high end there is always Trimble which has been in the GPS business since the beginning and makes probably the finest chart plotter available but your looking at an $8-10,000 unit depending on the bells and whistles.Good luck with your search--might also try some of the back issues of Practicle Sailor to see their comments which are usually on the money.
SHIMSHON is offline
post #3 of 6 Old 02-05-2002 Thread Starter
shimshon.
my choice is between furuno and raymarine.
which unit do you have?
eric
post #4 of 6 Old 02-06-2002
I actually went with the Northstar 952 XDW color chartplotter with WAAS. I found the resoulution and definition to be superior to both the Furuno and Raymarine. In addition it was much more user frienly and much quicker in acquiring a position. I also like the point and shoot feature which allows you to scroll out to some object or point you see on the horizon and it will identify itfrom its bulit in Light List (which can be updated), give you its position, course to steer, distance and ETA.The trade off is in price-- with the Northstar being sold for aprox.$3400
SHIMSHON is offline
post #5 of 6 Old 02-06-2002 Thread Starter
i guess i asked the wrong question. i was actually looking for a comparison between the furuno and the ray marine (raytheon)
chart plotter radar.
anyone have info on this?
eric
post #6 of 6 Old 02-17-2002
SFBay Sailor
nhsail's Avatar
Dock
I have the Raymarine RL74RC, had the RL72RC on earlier boat. This unit is easy to use, gives reliable operation on my Bermuda 40 and works with the CMAP chart cartridges.
Only downside I See is that depending on the scale of the CMap cartridge, you might have some zooms that are hard to resolve on a small 7" monochrome screen
nhsail is offline
Marine Electronics For Dummies Bluesmoods herSailNet 13 01-13-2014 09:39 AM
Peel Away Marine Strip II is the same as Standard Peel Away foxglove Gear & Maintenance 2 04-08-2004 10:13 AM
Marine Electronics For Dummies Bluesmoods Gear & Maintenance 1 04-07-2003 12:56 PM
Noaa Marine Weather Images Ocean-Pro Cruising & Liveaboard Forum 1 01-04-2002 07:14 AM
Kato Marine Davit Systems waddison Gear & Maintenance 0 11-27-2000 11:14 AM
