05-15-2007
Originally Posted by txmatt
When I did mine I just sanded the inside of the hull around it then put down a few layers of glass, let that set up and then faired it from the outside using thickened epoxy. Very easy and my boat hasn't sunk yet.
On a seperate but related note, I'm still trying to get my in hull transducer working.
First, you really need to patch the hole that the previous transducer was in with glass from both sides... grinding it out to about a 12-to-1 bevel... and then filling it by laminating glass over it from both sides... doing it just from the inside is asking for a problem later on IMHO.
As for your in-bilge shoot-through-the-hull transducer, you might want to use the PVC pipe and mineral oil method that I normally suggest. It seems to work far better than using putty or epoxy from what I've seen.
