05-15-2007
I'd reccommend that you go with a next-gen anchor like the Rocna, Spade, Buegel, or Manson Supreme. These are basically very similiar in design and are designed to set very quickly, and to re-set in the case of current/wind shift. Get one in about the same weight range as your current CQR, and I think you'll be very happy with how well it holds.
Personally, I own a 15 kg Rocna... which I bought on the recommendation of a friend. It is my primary anchor, and my only real complaint with it is that it brings up a bit too much of the bottom with it in general.
