Old 02-06-2002
BallastBoy is on a distinguished road
Corroded lifeline stanchions
3 of my 4 stainless stanchions have corroded and fused to the aluminum toerail including the nuts and bolts. I would like any advice on removing them and either reattaching them or replacing them. I''ve read that Tef-gel would prevent this from occuring. Thank you for responding.
BallastBoy
Old 02-07-2002
joub is on a distinguished road
Stainless steel and aluminum corrode because they are disimular metals. They must be kept separated as much as possible.
One way to accomplish this is to make a thin "gasket" of some non-conducting material to place between the two metals. I''ve used electrical tape on the back side of stainless fittings bolted to the boom/mast and it seems to do the job. Coat attaching bolts with an anti-seize compound when putting everything back together.
Jim
Old 02-08-2002
kimberlite is on a distinguished road
TRY DURALAC. PRACTICAL SAILOR SWEARS BY IT. I HAVE USED IT ALL OVER MY BOAT AND CAN REMOVE SCREWS THAT HAVE BEEN IN FOR 4 YEARS.
ERIC
Old 02-08-2002
Thanks for the replies! Any thoughts on how to seperate them without doing major damage to the toe rail? I suppose I could drill out the bolts, but how about seperating the actual SS stanchion base from the aluminum toe rail? Could I cut or chisel them apart?
I would assume that replacing them would be a smart move for safety''s sake anyway.
BB
Old 02-08-2002
did you try heat?
eric
Old 02-13-2002
Eric, you''re the second person to recommend that method, so will give it a try. Thanks again.
Old 02-28-2002
miahmouse is on a distinguished road
Don''t know about getting them apart but when you go to put the new ones on use lanacote(don''t be stingy with it either). Its another anti-corrosive that comes in a spray and a paste. Goop it all over everything and you''re good to go.
Need new stanchions (34ft. C&C) maureena5 Gear & Maintenance 8 04-19-2007 05:57 PM
Lifeline Netting wannasail Gear & Maintenance 6 06-12-2002 02:08 PM
life line stanchions HerbertFriedman Gear & Maintenance 1 12-09-2001 06:01 PM
Stanchions RobGallagher Gear & Maintenance 7 11-25-2001 05:09 AM
lifeline stanchions bernie-t Gear & Maintenance 4 02-03-2001 12:46 PM
