- Quick Menu
05-20-2007
Helms ALee!
outboard in motor well...
salt water, yamaha 8hp, fresh water flush connector that I use. It's a bitch to get in and out of motorwell, my lazyness says just leave it in there and watch the zincs but my common sense says take it out except when sailing. Then my laziness says, ok, but where would I put it? I would have to rig a sling to get it in and out, it's too heavy and it's a tight fit.
What does everyone else say?
05-20-2007
Larus Marinus
Dunno... If its washed clean of salt, kept dry and well ventilated, temperature average 20C - doesn't that describe any good storage condition?
05-20-2007
If the boat is kept in the water, you're probably better off taking it out, except when you're actually using the boat. It will reduce the chances of bad things happening to the outboard, like corrosion, and also reduce the chance of fouling the lower drive unit and prop. One guy I know is building a rail mount system for his outboard, which is in a motor well, so that he can haul on a line and have the engine just come straight up. It would store on the rails, when not actually in use.
05-20-2007
You're a step ahead of me. My 8hp Honda is in a well, but without any way to flush. My motor stays on the boat and in the water year round. Once a year when I take the motor out to change the oil and the like, I paint the outdrive and prop with all the appropriate primers followed by Interlux Trilux 33. I change the zinc at the same time, even if it's minimally corroded. I've found that once it gets corroded, the remaining zinc degrades rapidly. I also avoid the use of any shore power to eliminate trace currents that could cause electrolysis.
05-20-2007
Helms ALee!
The motorwell is enclosed, so the motor can't be tilted up and out of the water. So the bottom part of the shaft is always in the water.
05-20-2007
More than anything, you want to be able to flush the cooling system with fresh water pretty regularly or you'll end up with clogged arteries and that's never a good thing
I say rig a sling if for no other reason but to flush it out
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
05-20-2007
Helms ALee!
Anyone have picts of slings to share?
05-21-2007
Helms ALee!
How long have you been doing this? Salt water or fresh? Do you ever flush?
One guy in the slip across from me takes his 4hp out and puts it in a bucket of fresh water and runs it for like 15 minutes every time he goes out. I'm thinking this is excessive.
05-21-2007
The motor just celebrated it's 10th birthday. For the first several years, I took it off each winter, but haven't done that last few years. It's too hard to get back on if there's a nice day. The motor doesn't have any way to flush, so, no, I don't flush. I know I'm playing Russian Roulette, but I don't have much of a choice. The motor is just to big to heft in and out each time. The hole in the well that the shaft passes through is small, so that doesn't help matters.
05-21-2007
Okay, I have a thought. Imagine this. You get some very heavy canvas and sew it into a big 'sock' to enclose the lower part of the motor and come up as high as you can, with a strap to come over the top of motor. You install a small (the tiny Rule unit) bilge pump, with the outlet plumbed with PVC to act both as a drain, and as the 'stick' to push the sack down beside the outboard. When down sailing for the day, slip the bag over the bottom of the outboard, secure it, and pump out the seawater. Then fill it with fresh water and flush the engine, then pump that water out as well. It should protect the bottom of the engine quite well while sitting in the slip, but probably can't be used under way. (Drag, as well as preventing an emergency engine use.)
Just a thought. Oh, almost forgot, you need to treat the canvas with waterproofing, inside and out, and will know when to do it by the water coming in.
Hawk
| Thread Tools |
Search this Thread |
