Old 05-20-2007
Alden68's Avatar
Armchair Horn Sailor
Alden68 is on a distinguished road
Barnacles
What is the best way to remove barnacles from a bronze prop and what is the best way to keep barnacles from attaching themselves in the future?
Thanks
Old 05-21-2007
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
A small scraper will knock the barnies off your prop. Only sandpaper or a grinder will remover their "holdfasts" (the white, calcarous discs left behind.)
As far as keeping your running gear clean in the future goes, I have yet to actually see this stuff in action, but "PropSpeed' is supposed to be da bomb.
West Marine: PropSpeed Product Display
"Clean bottoms are FastBottoms"
Old 05-21-2007
ebs001's Avatar
ebs001 is on a distinguished road
PropSpeed is awefully expensive - about the same price as a new prop. I've read that lanolin works quite well but I have no indication how long it lasts.
Old 05-21-2007
Here .. Pull this
Sailormann will become famous soon enough
Saaw a blurb in Canadian Yachting magazine about something called "Maxwax". They have a website Corrosion Technologies Corporation The blurb says that it was developed as a
"corrosion inhibitor but recently boaters in New Zealand are having excellent results using MaxWax as a marine growth inhibitor. The coating is flexible, won't crack or lose its resiliency and marine growth just can't gain a foothold. It is non-toxic and biodegradable."
Have never seen or used it personally, so can't vouch but it may be something to investigate further.
Old 05-21-2007
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
Thumbs up 1792 Zinc Coat Barnacle Barrier from Petit...
From Petit...using it this year for the first time, so far (2 months) so good.
http://www.petitprod.com/fileshare/p...ds/1179320.pdf
Pettit Marine Paints - Browse Catalog
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 05-21-2007
captlar's Avatar
can't re Member
captlar is on a distinguished road
The story with the permanent marker goes this way - yards servicing props and writing pitch in marker noticed marine growth did not form where they wrote. I don't have any first hand info, but it is a cheap try assuming your boat is not in the water.
We use a painters scraper with different curves, but our favorite is a hard plastic kitchen spatula with round end. We use it on inflatable as well and it clean's em up quick and does not dig into fabric. If you winter haul, leave the holdfasts until spring - they dry out and pop off more easily.
Larry
"We have met the enemy and he is us." - Walt Kelly's Pogo
Old 05-21-2007
Alden68's Avatar
Thanks for the input. I've heard the marker trick.....I wonder.
Maybe I'll try that pettit marine product.
Thanks again.
Bottom growth and its effects on speed Iraklis Gear & Maintenance 15 01-09-2007 10:13 AM
barnacles affecting steering sgaterboy General Discussion (sailing related) 11 12-12-2006 09:40 AM
