Old 05-22-2007
Ronbye's Avatar
Ronbye is on a distinguished road
Dyna Starter
My Rival 32 has a Volvo MD2B Diesal engine which is equipped with a Dyna Starter (some people refer to them as a starter-generator). I have had no trouble with this dyna starter but have noticed for the first time that it gets very hot when in operation. As there is no unusal noises coming from it, I.E. bad bearings etc., I am not sure how hot these things should get.
Does anyone know if this is normal?
Old 05-24-2007
groundhog is on a distinguished road
Hi,
I have an MD6A also with a dynastarter and generator combo unit.
It does get quite hot also. I bought the boat last season so I don't know if this is normal.
But.. I have my belts to the dynastarter very loose because if it is, infact the bearings that are getting old, the lighter load on them will prolong it's life.
I plan to get the thing opened at some point and have the bearings changed out.
groundhog
ps. generator is not connected.
pps. also, i just remembered. I did talk to a starter guy that says if the thing is conected to the circuit wrong, it may be producing heat electrically by working against itself.... developing..
SeaVolt 800 Starter battery...add AGM..? marinesniper Gear & Maintenance 4 01-03-2007 10:36 AM
Starter verses Alternator ambianceack Gear & Maintenance 3 10-10-2006 09:28 AM
House and Starter battery hookup gmenrule Gear & Maintenance 7 06-10-2006 06:21 PM
Starter or House Battery? rrobar Gear & Maintenance 2 12-30-2003 03:56 PM
Starter Problem pehrst Gear & Maintenance 2 08-29-2002 08:34 AM
