05-22-2007
If you're going to fill it with epoxy, use colloidial silica and graphite as the fillers. The collodial silica will give it a lot of strength and the graphite will allow it to act as a bearing surface. An advantage of using thickened epoxy over stainless is that the epoxy doesn't suffer from corrosion issues.
