Old 05-23-2007
theArchitect is on a distinguished road
Battery Charger and Selector Switch Position
If I'm plugged into shore power and my charger is turned on, does it make any difference what position the battery selector is set on - 1,2,both,off? Thank you!
Old 05-23-2007
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
Depends on how you have the charger wired to the batteries. If it goes through the switch before the batteries, then yes, it matters. If it doesn't, then the switch is irrelevant.
Currently at 25 46 43 N 80 11 08 W
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 05-24-2007
stevemac00 is on a distinguished road
Battery chargers need to see a load so it's almost a certainty they're wired directly to the batteries and thus independent of the switch.
You should look for a smaller gauge wire attached to the battery and trace that back to your charger.
You didn't ask but the same isn't true for the alternator charger. Usually that's the same heavy gauge wire that goes to the starter from the common output on the battery switch. So when you're under engine power, be sure to switch to both/all batteries.
Old 05-24-2007
Thanks for the feedback! If the switch should be set to both batteries while underpower, It should be set to both batteries when I start the engine since I should not change the switch setting while the engine is running, correct?
Old 05-24-2007
Cruisingdad's Avatar
Best Looking Moderator
COrrect. DO not move the switch when running (well, I think you can go from 1-2-both as long as you do not go to off... but better not try that at home. Best rule of thumb is just not to do it.
Truth is that there is no reason not to keep that thing at ALL/Both. Always keep your batts parallel. Period. If you do not have a seperate engine batt, get one and take the time to put it in - or get to be good freinds with Sea Tow.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 05-24-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
It was covered here: http://www.sailnet.com/forums/gear-m...roper-use.html
