Icebox question - Page 2 - SailNet Community
post #11 of 14 Old 05-30-2007
A gallon of juice used for distructive testing. What a unique concept. Being more realistic, There should be engineering numbers available to better evaluate the strength and durablility of this material.
Duke
Duke 7184 is offline
post #12 of 14 Old 05-30-2007
Here .. Pull this
Have you looked at these units ? Look at the Top Loaded refrigeration units in the "Products" section - using one of them will be fast, probably cost less and may well have a better finish than a home-made unit:
Isotherm
Sailormann is offline
post #13 of 14 Old 05-30-2007
A gallon of pineapple juice is probably 8 lbs. or so. If the can is thrown with maximum force at the panel, and hits on the edge of the bottom, it has a fair chance of breaking the panel... since all the force will be concentrated in a very small portion of a square inch.
sailingdog is offline
post #14 of 14 Old 05-30-2007 Thread Starter
According to the manufacturer here are the Mechanical Properties:
Lengthwise Crosswise
Tensile Strength - ASTM D 638 (psi) 30,000 7,000
Tensile Modulus - ASTM D 638 (psi) 2.5 x 10^6 0.8 x 10^6
Flexural Strength - ASTM D 790 (psi) 30,000 10,000
Flexural Modulus - ASTM D 790 (psi) 1.8 x 10^6 0.8 x 10^6
Compressive Strength - ASTM D 695 30,000 15,000
Izod Impact Strength (ft - lbs/in) 25 4
Barcol Hardness 45 45
The manufacturer describes it as one of the strongest and most durable materials available.
Mithril is offline
Icebox Drain Gulfislander Gear & Maintenance 10 09-01-2008 12:01 AM
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
GPS question wallm General Discussion (sailing related) 13 05-30-2004 02:10 AM
Insulating an Icebox SailNet Gear and Maintenance Articles 0 07-22-2002 08:00 PM
