What to use to clean the prop?? - Page 2 - SailNet Community
post #11 of 38 Old 05-25-2007
Perhaps if you could figure a way to get some water flowing past the prop when under way it might not foul so badly. Just a suggestion.
bob
gettin' closer
cockeyedbob is offline
post #12 of 38 Old 05-25-2007 Thread Starter
Now this is one post I did not understand.....what do you mean water flowing???
Giulietta is offline
post #13 of 38 Old 05-25-2007
CalypsoP35's Avatar
Originally Posted by Fstbttms
"Clear anti fouling paint"? That's a new one on me.
It's made for lower sections of outboards. It's not bottom paint.
CalypsoP35 is offline
post #14 of 38 Old 05-25-2007
I don't discuss my member
Fstbttms's Avatar
He's making a joke. He means "Maybe if you sailed the boat more often..."
Fstbttms is offline
post #15 of 38 Old 05-25-2007
Fstbttms's Avatar
OK, got it. Still don't think it comes in a "clear" finish.
Fstbttms is offline
post #16 of 38 Old 05-25-2007
christyleigh's Avatar
Made by Tempo, but discontinued a couple years ago. I used it for years on different boats with bronze props with ok....... results... usually under 20 barnicles and not much other crud for our 6 month season.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
post #17 of 38 Old 05-25-2007
Rapid loss of zinc sends a message. What mix of metals do you have?
Goodnewsboy is offline
post #18 of 38 Old 05-25-2007
Seņor Member
TrueBlue's Avatar
Giu - If not yet done, and as I mentioned in the other thread, I would advise you install a galvanic isolator in your shore power connection. There appears to be some serious pitting of the saildrive's aluminum casing and excessive zinc loss due to electrolysis, and/or galvanic reaction. Aluminum and zinc are both less noble metals than the bronze prop.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #19 of 38 Old 05-25-2007
Seņor Member
TrueBlue's Avatar
This ProMariner Zinc Saver, a galvanic isolator, is what I installed on my boat a few years ago. Prior to that, the 40 mm prop shaft zinc anode would completely dissolve before season's end. At most, I now only lose about 25% of it at year's end.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #20 of 38 Old 05-25-2007 Thread Starter
CEB......my boat sails more in one year than most boats here in 3 years, believe me...but was stopped still for almost 2 months when the boom broke. That is when it got dirty... and when the boom arrived I went sailing rtaher than fixing it....
The zincs are coming out a new ones installed, I guess I'll have to replace them more often. These are from early march 2006, so been in water for a year and 2 months. So they paid their dues...
My original question is what to use to clean the prop so it does not get damaged on cleaning...you know...what brush etc. I want to do it myself...then...what to put on it, because the barnacle slow me down.
Christyleigh, I called Westmarine and they said the clear anti vegetative they had for outboard was removed because it had some weird bad chemical, but I bought a can of Propspeed kit, and will try it. Its is expensive though.
Goodnews, I did not understand what you mean by mix of metals. Please explain. I have the bronze Gori Prop, and the saildrive column...these are all standard materials in the industry..
Prop walk with a Max Prop ikent Gear & Maintenance 19 06-05-2011 08:32 PM
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 10:40 AM
Max prop on a saildrive levenezia Gear & Maintenance 16 09-20-2006 12:07 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Choosing a Prop Sue & Larry Gear and Maintenance Articles 0 12-24-2001 07:00 PM
