05-29-2007
Originally Posted by ereuter
The head swivel turns freely - the thing that is hanging up is the device that links the rotating parts to the headstay. It is difficult to turn even without a sail on it.
It sounds like you're saying the drum is hard to turn. If so, I had the same problem. When the sail is unfurled, the furling line is rolled up on the drum. I found that the previous owner had replaced the furling line with one that was oversized. When the sail was unfurled, and the line was rolled onto the drum, it made such a thick roll that there wasn't enough room on the drum to hold it all. The result was that the mechanism would jam before the sail was completely unfurled. I could unfurl the sail the rest of the way if I went forward and turned the drum by hand. I'm replacing the furling line with the size specified by the manufacturer. I'm finishing a bottom job and haven't launched yet, but I'm sure it will solve the problem, because, after I removed the old furling line, all parts of the system turned freely.
