Old 05-29-2007
Tubsmacker's Avatar
It's the Appeal of Steel
Tubsmacker is on a distinguished road
Send a message via Skype™ to Tubsmacker
Hot Sun, Warm Beer!! Help needed!!! (fridge failure)
Hi Guys, I've got a fridge problem with an Isotherm ASU 3200 12V UNIT
It's a self build kit which has 3 major components seperate fronm the cool box.
It has a winged plate device which attaches to the compressor which the chandlers in England describe as a the compressor thermostat.
There is a replacement part for this system which I am being asked to pay £300 for ($600) which I think is excessive for what appears to be only 25% of a 13 year system that might not even work if I replace this part as I don't know why it failed initially. the chandler wants around $1400 to $1500bfor the latest version that looks prety similar in the photos.
I just want cold food and beer. I have manged to reduce the stress here in Portugal by lowering the beer into the water which makes it drinkable cold for now.
Can anyone offer some advice on the best route forward? Are these thermostadt thingies repairable? (this one smelt like burning plastic and has obvious signs of over-heating)
Yours hopefully
Tubs UK (Boat in Portugal)
Old 05-29-2007
wildcard is an unknown quantity at this point
I have decided, I think, to not repair my onboard frig system and use a super insulated ice chest and one of the portable ice makers...This is untill I can leave for months on end.
Old 05-29-2007
camaraderie's Avatar
moderate?
Tubs...here is the isotherm manual:
http://www.great-water.com/pdf/Isoth...3200ASUman.pdf
If this is what you have...then it is a conventional holding plate compressor systm with a separate thermostat control panel. I don't know what the wingd plate is unless you are referring to th stsainless steel holding plate which sits inside the fridge box. The Thermostat itself is attached to the holding plate and a wire runs from it to the control panel. If you are being quoted $600 for JUST the thermostat that is pretty outrageous...but if for both holding plate and thermostat then it is pretty normal. The total price of $1400 bucks for a complete new system sounds resonable also. You can get cheaper complete units that will cool things down...but not as well as a holding plate...around $1000.
Old 05-29-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
You can also get an Engel 45 for around $650 and it only draws .07 amps.
S/V Scheherazade
Old 05-29-2007
I'd second the call for an Engel M45. PS just rated them as best small refrigerator in a recent issue. Also, can work on both 12 VDC and AC.
Old 05-30-2007
Tubsmacker's Avatar
Hi Guys and Thanks for the input. Cam, the holding plate is hidden in the fridge box. The bit that has gone is attached to the compressor with a 3 pin push on I think the description is the 'electronic control unit' in the manual that you very kindly sent me the link for.
I rang the manufacturer from the phone number on that manual and they were very helpful and are sending me the part I need for about $320 which is quite acceptable. The English suppliers knew exactly what I needed and sought to 'spank' me for $600. Thanks to you Cam, I am now on the right path for cold beer sooner rather than later.
Thanks Sailnet ,and to everyone who answered my 'warm beer mayday'
I also stumbled upon a mini beer keg with pump in a local supermarket that is currently at a depth of about half a metre cooling off!
Regards,
Tubs
Old 05-30-2007
moderate?
Well that seems to have worked out rather well! Have a cold one and smack a few tubs for me!! (Would you also ask Michael Owen to start pulling his weight!!??)
What Time Is It? Jim Sexton Her Sailnet Articles 0 03-24-2001 07:00 PM
