Replacing SeaCock Gate Valve with Marine Ball Valve - Page 2 - SailNet Community
post #11 of 31 Old 05-31-2007
Maine Sail's Avatar
Cam...
Originally Posted by camaraderie
Wood (marine ply or Teak) is fine but once you have it "fitted" well to the hull form then coat it with epoxy to avoid deterioration and then bond it to your hull using 3M 4200 or the equivilent. Note that the screws into the wood are just to keep it from turning. the real strength of the application is from the compression of the screw threads.
Cam the screws on flanged sea cocks are meant to go all the way throught he hull and they are not designed to be "wood screwed" into the backing plate. The idea of a flanged through hull is that you have multiple fastening points including the through hull and the three silicon bronze machine bolts..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 31 Old 05-31-2007 Thread Starter
saurav16's Avatar
Send a message via AIM to saurav16
Helekai,
I was looking at this apollo fitting
http://www.defender.com/product.jsp?path=-1|51|106370|813148|319675&id=142110
It is bronze but silver in color. Could you use a standard bronze thru hull fitting that is bronze in color?
saurav16 is offline
post #13 of 31 Old 05-31-2007
Maine Sail's Avatar
It looks silver but..
The picture makes it look silver but I'm fairly sure it's bronze in color. Always use bronze srews with bronze sea cocks!
______
post #14 of 31 Old 05-31-2007 Thread Starter
saurav16's Avatar
Halekai,
The through hull has to be purchased as well. I was looking at mushroom style bronze ones. They have a threading and a nut that threads on. Does the seacock also screw onto the threading of the thru hull? If so are the threads standard?
saurav16 is offline
post #15 of 31 Old 05-31-2007
pigslo's Avatar
Countersink the flathead machine screws from the outside of the hull and cover and fair with thickened epoxy. Hopefully your hull is thick enough to do this. Take advantage of being out of the water.
pigslo
pigslo is offline
post #16 of 31 Old 05-31-2007
Maine Sail's Avatar
Originally Posted by saurav16
Halekai,
Yes you need to also buy the thru hull. It threads into the sea **** but you don't need the nut if using with a real sea ****. Depending on your hull thickness you may need to cut the through hull a bit shorter, with a hack saw, or it will bottom out in the sea **** before it's tight. Apply 4200 to the threads after the sea **** has been mounted and beded. Then thread in the through hull from the out side using a liberal amount of 4200 around the mushroom head. It's imperative that you do a dry fit to m ake sure all lines up and fits well before applying 4200... I buy all mine from Hamilton Marine. My new boat is actually on the hard and I'm doing this exact upgrade as we discuss it here. So far I have about $450.00 tied up just in bronze......
______
post #17 of 31 Old 05-31-2007
Thanks Courtney.
Halekai- Since you are the local expert, can you thread the seacock on over the thruhull nut? When I threaded the ball valve onto the thru hull it threaded on pretty well, but was "stiff". (now I know why) Good thing I'm not a plummer. I'm not sure I have room for the flanged seacock (near motor mount and not much clearance.), if not is there a thread adapter to get to the type of thread on the ball valve.
FYI, it's almost under the engine with exactly zero chance of anything ever rolling, sliding, falling, dropping, or otherwise moving into / onto it.
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #18 of 31 Old 05-31-2007
moderate?
camaraderie's Avatar
Halekai...I thought he was talking about the base of the sea-**** AFTER he puts the threaded compression mount thru hull like this:
Followed by something like this.
Actually...I prefer all Marelon fittings as I find them both reliable and less prone to seizing up...and easliy un frozen.
camaraderie is offline
post #19 of 31 Old 05-31-2007
Marelon doesn't corrode either.
sailingdog is offline
post #20 of 31 Old 06-01-2007 Thread Starter
saurav16's Avatar
Where do you guys order these fittings from?
saurav16 is offline
Gate valves, with scary photo pmoyer Gear & Maintenance 61 04-11-2007 01:55 PM
Thru hull stuck Jotun Gear & Maintenance 25 03-11-2007 09:20 PM
Marine Radios Overview Jim Sexton Seamanship Articles 0 09-30-1999 09:00 PM
Marine Radios Overview Jim Sexton Gear and Maintenance Articles 0 09-30-1999 09:00 PM
Marine Radios Overview Jim Sexton Her Sailnet Articles 0 09-30-1999 09:00 PM
