05-30-2007
If you're going to ever have to remove the spreader lights, you'll be wishing you used screws. Pop rivets should only be used for hardware that will generally not need replacing, like padeyes. It is difficult to wear out a padeye or upgrade a padeye.... since they're relatively low-maintenance and very difficult to damage.
As an alternative, you could pop rivet a base mounting block to the aluminum spreader arms, say made of starboard or something similar, and then use screws to attach the light to the mounting block.
