Is a propane Solenoid supposed to be hot ??? - Page 2 - SailNet Community
post #11 of 16 Old 05-09-2009
Warm is probably OK, but the only hot one I encountered failed, and it was so hot we worried about its proximity to the propane. A yard said to tap it to get the plunger working. The heat was due to poor electrical contact. It kept seizing, so it got replaced. But not before we had to go two days at sea without coffee, then remembered the boat had an inverter and small microwave...
floatsome is offline
post #12 of 16 Old 05-10-2009
poopdeckpappy's Avatar
I don't get the safety aspect of a solenoid, it sounded like a safety hazard to me so I opted not to install one. when we're done with the stove, we turn the tank valve off, bleed off the LPG then shut the stove off........imo it's safe & simple, uninterupted from reg to stove
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #13 of 16 Old 05-10-2009
Grasshopper
JiffyLube's Avatar
I think the solenoid is more for convince than safety.
JiffyLube is offline
post #14 of 16 Old 05-10-2009
Bender of Nails
Xintex makes a pretty good safety system whereby the solenoid is powered through LPG sensors - any leaks and the solenoid kicks off. I think they can also receive input from a CO monitor, though I've never wired one that way.
"Verbosity leads to unclear inarticulate things"
~Dan Quayle
Deadeye is offline
post #15 of 16 Old 05-10-2009 Thread Starter
Here .. Pull this
My solenoid is also part of a safety control system made by Trident. There are two sensors that turn the solenoid off if they detect propane gas. It is very convenient because all we need to do when we cook is press a button in the galley and the propane is ready to go.
Sailormann is offline
post #16 of 16 Old 05-27-2009
Propane Solenoid Hot
The prior owner of our boat installed a propane system with a solenoid and a Xintex propane "sniffer". We have been using it without any problems for all of the '08 and the beginning of the '09 season. When the solenoid is activated to allow propane to flow into the lines, it always gets quite warm - warm enough that you wouldn't want to hold your hand on it for more than a few seconds. Because I know heat = energy, I have made a habit of turning the solenoid off ASAP after use. When not in use, the solenoid is room temp. I believe this is normal.
davmarwood is offline
Tankless propane hot water tijel Gear & Maintenance 5 05-24-2006 07:44 PM
On demand propane hot water heaters pjfsail Cruising & Liveaboard Forum 8 07-01-2005 02:47 PM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 08:00 PM
