Old 06-01-2007
geary126 is on a distinguished road
Teak Prep--Mysteriously Darkening Wood
So, I'm on day 101 (held hostage) of this fricking varnishing process. Orbital sanding, hand sanding, you name it.
On this perfectionistic kick, I used Ajax (per Don Chase) to bleach one piece of wood lighter...slathered it on, damp, scrubbed, rinsed after :30. Next thing you know, I have dark spots that won't even sand off!
What the hell?!
Anybody have any luck with Ajax, or should I just use Oxyacyic acid.
I swear, this boat is two steps back, for every .5 forward..!
Also: I'm pouring the varnish into an empty quart can, clean with a lid, so I can strain it and add thinner. Can this sub pot be used for successive days, or is the "paint can du jour" only good for the day?
presume I seal it.
thanks, guys.
Old 06-01-2007
VASailor10 is on a distinguished road
I had a friend who just re did his teak. He told me if possible remove the teak off the boat. Then sand the teak down to remove wear and clean it. Then put teak oil on followed by your varnish or laquer.
-Spencer
Old 06-01-2007
Varnish is off the boat, taking up about 25% of garage (and 75% of my wife's patience)
Hence, need for speed..!
Old 06-01-2007
RichH's Avatar
RichH will become famous soon enough
If the bare fresh bleached teak is in sunlight, what you're probably noting is the sunlight changing the 'hue' (color development) of the wood. Either varnish it as soon as possible after bleaching .... or wait a few days in full sun to let the UV completely affect the change of 'hue'.
I usually bleach (oxalic), let dry, cover with saran wrap and let 'soak' in the sunlight for a few days before varnishing, etc. .... (and then use very diluted 'washes' of aniline dyes, etc. to add color to those few areas/zones that dont 'develop' to the overall color I want.
Old 06-01-2007
thanks, Rich. The Ajax thing may have been a bad call.
Old 06-01-2007
RichH's Avatar
Not really. Teak is a 'natural botanic' product. Natural botanics are never ever uniform in structure or chemical composition (zones, etc.). What you experienced could simply be 'natural' chemical reaction in one area and not in the surrounding areas because the chemicals in those 'zones' are a wee bit more or less concentrated, etc. there. If you want 'uniformity', then consider a 'plastic'.
When bleaching, staining, etc. usually it best to 'work up' or 'work down' to the color or hue you want by using diluted solutions of whatever your using. Using diluted agents will make the process take longer but you can stop if something becomes 'adverse' or undesireable. If you use potent chemicals and at 'full strength' sometimes the reaction happen so fast that you dont have time to react to stop, etc. if its not to your desires.
Old 06-02-2007
travler37 is on a distinguished road
Pounds his MANLY beer belly!!!!!!!!
Said ADMIRAL should go garden or something............
Opens a MANLY beer as he puts a load in the wash,feeds the critters,looks at weather and decides rain/roofing is a bad idea......
Slinks to ADMIRALS mini-van to do repairs......
M
Old 06-02-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
I don't know what's in it exactly, but that store bought Teak cleaner works extremly well. Personally, I like to just sand the teak a bit, slap some teak oil on it and within the hour go sailing. If you keep up with it, the teak will only require a quick re-oiling once in awhile and then, yep...Go Sailing!
Old 06-02-2007
Thanks, guys.
How about storing the strained, mixed (50% varnish + 50% thinner) varnish overnight, for use on Coat #2? Is that a bad call, if I can seal the can?
Old 06-02-2007
Sabreman's Avatar
Sabreman will become famous soon enough
You can probably get away with it this time, but it's generally best to strain varnish prior to each session.
Sabre 38 "Victoria"
Little Harbor 38 Kerwood Boat Review and Purchase Forum 11 08-27-2007 06:49 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Teak versus Marine Wood RookieHunter Gear & Maintenance 1 11-29-2002 08:30 AM
Homemade Teak Decks SailNet Gear and Maintenance Articles 0 08-01-2002 08:00 PM
Bristol Teak Tom Wood Gear and Maintenance Articles 0 11-02-1999 07:00 PM
