How do u know if winches are shot - Page 2 - SailNet Community
post #11 of 18 Old 06-04-2007 Thread Starter
saurav16's Avatar
Send a message via AIM to saurav16
Hi,
Instead of using winch lube can you use marine lube for the bearings of the winch?
saurav16 is offline
post #12 of 18 Old 06-08-2007
I have plain old waterproof boat trailer wheel bearing grease on board which is used for everything mechanical that requires grease. The words on the container say it is for all marine equipment.
Goodnewsboy is offline
post #13 of 18 Old 06-08-2007
Any good waterproof, corrosion-inhibiting grease should work.
sailingdog is offline
post #14 of 18 Old 06-08-2007
I should add that, with respect to winches, it is probably not good to use grease to lubricate the pawls. Those need to move very quickly during operation and the high viscosity of grease may interfere. I think the manufacturers prescribe a light oiling.
post #15 of 18 Old 06-08-2007
Helms ALee!
tenuki's Avatar
Just a FYI, some manufacturers specify to not use grease with Teflon added. Did we mention not greasing the pawls?
tenuki is offline
post #16 of 18 Old 06-08-2007
How often do you do that?
Originally Posted by btrayfors
Winches need to be serviced periodically. I just did 5 of my cockpit winches (Barients from size #23 to size #31, all self-tailing).
Usually, all that's required is to disassemble them carefully, wash all gears and bearings in kerosene, check the pawls and springs, lube the gears and bearings with a waterproof grease (Lewmar makes a grease you can buy at West Marine), and put them back together being sure to get all the parts back in the right place.
It's not hard; it's just time consuming.
Springs for the pawls are easy to find. Depending on the make/model of the winch, pawls and other parts may be harder to find.
Bill
wumhenry is offline
post #17 of 18 Old 06-08-2007
Helms ALee!
tenuki's Avatar
Every year. Only takes about 30 minutes for my small/simple 4 winches, but I have the drill down pat. It's a simple mechanical device, but keeping it clean and properly lubed extends it's life and functionality greatly.
The PO never did it and I had to replace the bearings and do some repair work on the cylinders and spindles to get them operational again.
tenuki is offline
post #18 of 18 Old 06-10-2007
sorry did not mean to include lewmar, but maxwell.
mike dryver is offline
ISO advice re sizing winches brainstormers Gear & Maintenance 0 07-09-2004 07:03 AM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
