Using Seawater to cool Cabin - Page 2 - SailNet Community
post #11 of 12 Old 06-03-2007
Dallas, a small diaphragm pump just won't move much. While "chiller pipes" are a great way to heat or cool any space, the two problems you would have are running enough pipe in your boat to get the heat transfer you want, and then getting enough COLD water through them. To get cold water you typically have to drop an inlet hose below the thermocline, which can be 10-40 feet below surface level. And, if you pump seawater in pipes, critters tend to grow in them and block them, so you need to add a heat exchanger of some type, that you can clean out, and an inlet filter. The heat exchanger means you need two pumps now, one for each side.
Its always "just one more thing".
I've often wondered about using misting nozzles (either for gardening, or the type used on supermarket produce) above deck, letting either fresh water (need a source probably requiring a dock hose) or clean raw water (need good filtering!) mist down on the deck and letting that cool it from evaporation. That's a minimal power system--if you can meet the water requirements.
A white deck, white hull, and canvas (especially covering the foredeck) while not under way would seem to be about the only "sure wins" in bright sunlight.
hellosailor is offline
post #12 of 12 Old 06-04-2007 Thread Starter
Thanks all for your insightful messages!
DallasAB is offline
Adding ports to the cabin ChrisAndVero Gear & Maintenance 3 02-16-2007 10:46 AM
Proper Cabin Lighting Tom Wood Gear and Maintenance Articles 0 02-24-2003 07:00 PM
Proper Cabin Lighting Tom Wood Cruising Articles 0 02-24-2003 07:00 PM
Proper Cabin Lighting Tom Wood Her Sailnet Articles 0 02-24-2003 07:00 PM
Cruising Advice Needed!!! 2 or 3 cabin for 3 single guys? robbieturner Cruising & Liveaboard Forum 5 10-17-2001 05:26 AM
