06-03-2007
Tim, basically yes.
Inductive loads, surge loads, AC circuits and conversion factors (VoltAmps rather than Watts) all can make it complicated but even then, using Ohm's Law gives you a reasonable ballpark for normal use. Generally, anything that makes a "boink" noise when you turn it on (like a big TV set or stereo) or has to start a motor (air conditioners and vacuum cleaners) will be an inductive load that uses a great deal more power when it first turns on. That surge can be 2x-3x as much more as it routinely uses, but you probably don't need to worry about that stuff if you are just trying to figure out your power budget on a "small" craft. The nav lights, the radio, the intruments, all can be figured by Ohm's Law. If you have any electrical winches, an anchor winch, or electrical refrigeration on board, THOSE motors all have a surge, so they need fuses/breakers which can withstand the starting pulse, and they will consume way more power for the first second of operation, than they normally consume. Because the time is so short, you can usually just use a "fudge factor" for your calculations, if the name plate on them doesn't list the surge current.
