06-04-2007
It would help if you said who made the roller furling unit. Have you inspected the foil grooves to see if they are damaged at all. That is a common reason the sail won't continue up the foil, even if the head swivel will. Another problem could be the wire luff of the sail could be damaged. You should check that as well. Leaving it furled all winter, provided it wasn't left out in the snow all winter, isn't all that big a problem IMHO.
