06-05-2007
moderate?
saurav16...if your alternator was not working you would see a drain on your ammeter which you did not report so chances are that is NOT the problem.
To be sure...with the engine running for a few minutes, take a voltage reading at the posts of your batteries with the battery switch turned to the BOTH position. You should be seeing over 13 Volts. If less...then you DO have an alternator problem.
If over 13V then you either have a wire/connection problem like I first suggested OR a bad ammeter. Or perhaps you have your batteries switched to where the one with the ammeter on it is out of the charging/connected circuit and is simply sitting there doing nothing...hence the reading. Those are the simple things to check.
