Old 06-05-2007
Maine Sail's Avatar
PB Blaster/Penetrating Oil WARNING !!
Hi All,
I thought I sould let you all know that I discovered, the expensive way, that you should never use PB Blaster near ANY engine or transmission seals.
I needed to remove my shaft coupling so I sprayed the four bolts with PB Blaster, thinking nothing of it, and let is sit over night. Evidently some of it dripped onto my transmission output seal and when I went to the boat the next day the majority of my transmission fluid was in the pan and not the transmission.
My transmission is a 2003 ZF v-drive and had never, ever leaked a drop. After speaking with a few mechanics about this they know the problem well. PB Blaster can eat engine seals, transmission seals and plastic cups! Keep this stuff far away from any output shafts, engine seals or seals you don't wan't leaking.
PB Blaster is great stuff but also very dangerous to the tune of $800.00 on my transmission seals. Use it with caution and for it's intended purpose only!
______
-Maine Sail / CS-36T
Old 06-05-2007
Yup... it is a very aggressive solvent... even says so on the label IIRC. I hope you didn't try to run the tranny before you discovered the dead seals.
Old 06-05-2007
SVDistantStar's Avatar
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
Yea ive know of this issue for awile when i found it with the lower unit seals on an outboard of mine. Ive been useing Sea Foam Deep Creep now. Havent had any issues.
Oil Change experience - Lessons Learned kmeeks Gear & Maintenance 33 04-16-2010 08:55 AM
W60 - No oil pressure after oil change??? pma_foyl Gear & Maintenance 9 12-01-2004 09:45 AM
Changing Engine Oil Tom Wood Gear and Maintenance Articles 0 10-02-2002 08:00 PM
Oil Pressure Problems Tom Wood Gear and Maintenance Articles 0 05-16-2002 08:00 PM
Radar Proximity Warning Systems Jim Sexton Seamanship Articles 0 10-31-1999 07:00 PM
