Fricking Project Headache #2982B: GPS mount in Pedestal Guard - Page 2 - SailNet Community
post #11 of 13 Old 06-08-2007
Larus Marinus
Idiens's Avatar
Originally Posted by geary126
Question is, I think I need to drill a 3/4" into the rails...and then, into the cockpit sole. Bear in mind, the rail diameter is 1".
Don't, run the wire down the outside, sorry it's ugly.
Can you get into the pedistal instead?
Without pictures its a guessing game for us.
There are various deck attachments intended to take the cables from deck mounted masts through the deck. Would one of those fit?
Idiens is offline
post #12 of 13 Old 06-08-2007
Senior Moment
SailorMitch's Avatar
Makes me glad I bought a Standard Horizon chartplotter a couple of years ago. I mounted it on the pedestal guard using a Snap-it Marine base I already had, and then made a bigger base using Starboard. The SH wires run through the binnacle (yes, it is a tight fit but doable) to a wiring block down below. No fittings at the ends of the SH wires. Makes a neat, clean installation.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
SailorMitch is offline
post #13 of 13 Old 06-08-2007 Thread Starter
Hey, guys. thanks for notes.
SteveMac. You would think they would have a large connector only on one end, wouldn't you? But that 3/8 connector, somehow, won't even fit through a 5/8" hole. I tried it the other day.
maybe routing on the outside is the way to go.
I asked Edson, and they said, they didn't recco it, re: inside the pedestal.
Kind of the equivalent of NIMBY. Not in my backyard!
geary126 is offline
Wiring GPS: pedestal or pedestal guard? geary126 Gear & Maintenance 14 05-17-2007 02:43 PM
Handheld GPS Overview Tom Wood Seamanship Articles 0 05-31-2001 08:00 PM
GPS Gets More Accuracy Jim Sexton Seamanship Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Gear and Maintenance Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Cruising Articles 0 05-21-2000 08:00 PM
