08-10-2007
Jim,
These lines you see on each side of the center line, are normally seen on tactical compasses and what they do is they simply give you an automatic heading for your next tack in a regular race circuit. Meaning you only have to memorise one heading. They are normally set a 45º from the center lubber line, so your next tack will be indicated by the side lubber line!!! Smart huh??
Some compasses, the more advanced ones allow you to change the position of these lubber lines so that you can adjust the compass to your boat's tack angles, wind shifts, deviations to boueys etc. So some of them you can adjust from 25 to 50º lines, to adjust for wind shifts.
Their position sideways also allow you to read the heading if you are sailing a dinghy, where you are on a trapeze and not inside the boat, the side lubber line will be your reference.
Or in tiller boats, with compasses mounted on bulkheads, since you seat sideways, its easier to see a line that is offset as the tileer man is.
Hope this helped your question.
I have adjustable lubber lines on my compasses. And normally I have them set at 45º.
(And this concludes our broadcast, signing off)
