06-11-2007
I don't think you understand how much water sprays around, on, and into a small 22' sailboat. I have a 28' trimaran with an 18' beam, and it is one of the driest boats to sail I've ever been on. Last season, on a day with 20+ knots of wind and 4-6 foot seas, it took two hours before anyone in the cockpit felt any spray come aboard... and I would be hesistant to use a laptop that wasn't ruggedized in my companionway. That was the downwind leg. The upwind leg was a totally different story... and most were in full foul weather gear, since the cockpit was getting clobbered fairly regularly.
One other point I'd have to make is that the Garmin is going to use a lot less electricity underway, and the display on the Garmin is designed to be daylight readable. The unit also changes the color schema as the dusk arrives, to help preserve your night vision—this is something the laptop is not likely to be able to do.
