Panda Fisher with PTO? - SailNet Community
Blogs
Old 06-09-2007
dsbentley's Avatar
dsbentley is on a distinguished road
Send a message via AIM to dsbentley Send a message via MSN to dsbentley Send a message via Yahoo to dsbentley
I am looking at getting at 12 KW Panda Fisher to replace my older, loud 15KW Isuzu. The boat is now in the Virgin Islands and needs A/C for charter so I am looking at adding two 16,000 BTU systems and need a quite gen set. My Isuzu run another pulley system that runs my 2nd refrig system compressor and my emergency Jacbsco bildge pump. Does anyone know if I can run a PTO off the Panda Fisher gen set?
Old 06-09-2007
camaraderie's Avatar
moderate?
DS...I don't think you can do a PTO from the Panda as:
1. They must only be operated with the cover on
2. The manual says nothing but the battery may be run off the alternator which to me says that a PTO would draw too much HP off the unit.
Obviously...FP can confirm this : service@fischerpanda.com
Old 06-10-2007
dsbentley's Avatar
Thanksm I will check with PF to see what they say. Do you know of any other quite generator that is enclosed that can run a PTO?
Old 06-10-2007
all these confusing ropes
dohenyboy is on a distinguished road
Don't forget a full time mechanic to fix the Fischer Panda genset
A Precautionary Note on Fischer Panda Generators geoffschultz Gear & Maintenance 10 05-13-2011 01:15 AM
Fisher takes Thistle crown with 3 victories in 7 races (The Toledo Blade) NewsReader News Feeds 0 08-12-2006 08:15 AM
Fischer Panda Owner''s Forum Shutting Down geoffschultz Gear & Maintenance 0 12-23-2003 10:20 AM
Fischer Panda Owner''s Forum geoffschultz Gear & Maintenance 2 10-01-2003 06:45 AM
A Precautionary Note on Fischer Panda Generators geoffschultz General Discussion (sailing related) 2 12-19-2001 06:51 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
