Does anyone use a Electric Trolling Motor - SailNet Community
Blogs
Old 06-10-2007
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Thinking of a elec. trolling motor for the ( 8'6" Avon) dingy
Does anybody have one and if so, what size & how does it do??
I'm thinking maybe one around 40-55 LB/FT thrust might work, but would like to hear from you guys first
Tanks
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 06-10-2007
uspirate's Avatar
Trim for Sail
uspirate has a spectacular aura about uspirate has a spectacular aura about uspirate has a spectacular aura about
my bud used elect on his dink. dont remember what size motor, boat was about 9 feet. i actually was very impressed with it. lots of torque and silent. we used to cruise all through channel islands harbor and always had sufficient power.
signature
BJ & Nimfa
S/V Flocerfida
Old 06-10-2007
ChicagoNewport27's Avatar
Purveyor of Fine Ideas
ChicagoNewport27 is on a distinguished road
I started out with a Minn Kota trolling motor with 17lbs of thrust on my 8' Walker Bay knockoff dinghy. This worked great for me when I was alone (even with gear), but it was a bit pokey when I was shuttling myself, the Admiral and our gear (beer) out to the boat. I found a Motor Guide 28lb thrust electric trolling motor for $50 on eBay, which works perfectly. It'll even power us at a decent clip through choppy harbor waters on a windy day. Low weight, quiet, plenty of maneuverability, and very portable.
In my opinion, if your dinghy is mostly used in getting from dinghy dock to mooring field, all you need for locomotion is an Armstrong Engine (a pair of oars and your two arms) or an electric trolling motor. Harbors are no-wake zones anyway. You dont need to get your dinghy up on a plane or pull water skiers, you just need to shuttle goods and personnel to and from your boat.
Old 06-10-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
I have a 30 lbs. thrust I've used on seveal different boats including a 14' Al jon boat. It had plenty of power, so I would say go with a cheaper 28-30 pounder.
Old 06-10-2007
Bermuda30's Avatar
On Blocks
Bermuda30 is on a distinguished road
I've got a Minn Kota 30# I've used on my dinghy (7'10") several times. I like it, has enough power, and is silent.
Old 06-10-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
How do you deal with the battery to power the motor ? Solar ?
S/V Scheherazade
Old 06-10-2007
thanks guys, ya saved me some money, I'll look for something around 30lbs/ft
CN27, that is all I want it for, back and forth from dock to boat, or boat to boat, thanks for your input
Freesail, I was thinking a couple batteries to alternate, maybe something like Optima with a small battery tender like I used on the dirtbikes, have one charged or charging all the time.
1978 Tayana 37
Old 06-10-2007
In some larger anchorages, the trolling motor may not have the range you need. Also, if the battery dies you wil be at the mercy of the current unless you have the oars aboard. Finally, the weight of the trolling motor and battery may be more than that of a small four-stroke outboard motor. Gasoline provides much higher energy density at much lower weight than do batteries—a third-of-a-gallon in my 3.5 HP four-stroke Tohatsu will power it for almost hour of run time... carrying a two-gallon jerry can will give me seven hours run-time in a 45 lb. package.
Old 06-10-2007
can't re member
yotphix is on a distinguished road
If you want to do this, and you have any concern about running out of power, install a volt meter so you can keep track of your reserves and stay out of trouble.
Old 06-11-2007
Bermuda30's Avatar
On Blocks
I should have mentioned this, I generally row my dinghy, just experimented with this a few times for running around. Oars should ALWAYS be carried, whether its outboard, sail, or trolling motor powered, IMHO. Btw, I powered mine from an old Optima Blue top, mainly just from boat to boat.
electric trolling motors for small sailboats? thebrakes General Discussion (sailing related) 18 07-25-2010 02:29 PM
Electric Motors and Sailing Vessels Mark Matthews Gear and Maintenance Articles 0 11-17-2002 08:00 PM
Choosing and Installing an Electric Windlass Sue & Larry Gear and Maintenance Articles 0 09-06-2002 09:00 PM
The Great Windlass Debate SailNet Seamanship Articles 0 11-30-2001 08:00 PM
The Great Windlass Debate SailNet Gear and Maintenance Articles 0 11-30-2001 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
