  #11 (permalink)
Old 06-11-2007
T34C's Avatar
Thanks Courtney.
T34C has a spectacular aura about T34C has a spectacular aura about T34C has a spectacular aura about
What if the crew member is attached to the mast?
Maeven
Tartan 34C Yawl #282
Anything-sailing.com
Moderator
  #12 (permalink)
Old 06-12-2007
blt2ski's Avatar
I have not looked at the PHRF-NW site, nor have I contacted the local YC RC. BUT< the 80% of LP is probably what I am remembering in the gray matter of the brain. I do recall many NFS boats having a couple of marks on their poles for the appropriate HS they are flying at the time. IE marks for a 150, 135, 110 etc.
Along with George's comment about diminishing return when the pole gets too long. I was wondering if there was a general rule of thumb if you will on where this length was. Probably 85-90% which is what I would have guessed.
So the reality is, if I can find a 9-16 that would be ideal, a 8-14 would work, being as right now my biggest HS is a 135'ish. Smallest is a 110 besides the storm jib. Altho a 150-155 probably a drifter/reacher out of 2.3oz nylon, in the future for the light days here in the puget sound area.
As far as keeping my AS filled, not a problem with .75oz material in general terms. What I was trying to figure out, is if using a pole in straight downwind situations ie the 150-180 range, would help? While I may not be able to use it racing, maybe cruising where "rules" are not to be followed if you will. Right now, my AS is 580# or so, the max I have seen for my boat is about 680-700, with symetrics in the 750 range. What I have works really well for moving me alot faster than my 135, still faster than a 150 will do. So with that in mind, I am happy. If I want a bigger spinny, I will probably get a .5 symetric and go with that for lighter airs, the AS when it gets windier or reaching or get another bigger boat............
Marty
  #13 (permalink)
Old 06-12-2007
tenuki's Avatar
Helms ALee!
tenuki will become famous soon enough
ah, so here's the plan. buy a wisker pole that is too big, then use that as a rational for getting a bigger boat!
Spinnaker vs Whisker Pole jr438234606 Gear & Maintenance 2 04-09-2007 08:46 PM
whisker pole ?????? mangomike General Discussion (sailing related) 4 10-01-2006 08:05 PM
Whisker Pole vs Cruising Spinnaker r2straebel Gear & Maintenance 5 01-24-2002 08:25 AM
Using a Whisker Pole Dan Dickison Racing Articles 0 09-04-2001 08:00 PM
Using A Whisker Pole Dan Dickison Learning to Sail Articles 0 04-23-2001 08:00 PM
