Blogs
User Name
Old 06-11-2007
blt2ski blt2ski is offline
Whisker pole sizing
Is there a std size for lack of better term to size a whisker pole based on ones J measurement? or a combo of the LP and J measurement?
Also, while not normally used, sizing for a pole for a asymetric spinnaker? I am thinking for more straight downwind runs, ie 150-180* a pole would help my AS be a bit more usefull. It is a great sail flown loose in the 80-150* range!
Forspar recomends a 10-18' telescoping for my 30' boat, BUT, IIRC my local fleet in racing only allows a 70-80% of J pole for a whisker pole when racing, will verify this. So with a J of 11.5' 70% being 8.05'........at least for racing purposes, the 10-18 would make me illegal. I am not in the mood to spend $600-800 and just follow a books recomendation, if there is an actual formula to figure the proper size per say.
Thanks
Marty
Old 06-11-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
It depends on what you're using the whisker pole for.
If you're cruising and poling out an oversized Genoa, or an asymetric, then I would go with Forespar's recommendation, as the shorter pole is going to be a bit tight.
If you're planning on using it for races, then you need to stick with whatever the local fleet rules will allow you.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
Old 06-11-2007
jgeissinger jgeissinger is online now
jgeissinger is on a distinguished road
Whisker Pole
PHRF max allowable for a whisker pole is 140 per cent of J. The 70 to 80 per cent sounds not only strange, but pretty useless. Maybe they are talking about a reaching strut, which is something entirely different.
Follow SailingDogs advice and go with a bigger pole. I personally think that Forespar's suggestion is too big. I have a 11.2 J and use a pole that telescopes to 14ft. Its close enough, it is smaller when retracted, and it definitely does help in a variety of conditions.
Old 06-11-2007
The 140 sounds like a better number to use vs the 70-80 I am remembering someone mentioning in a skipper meeting last Jan. I was going to check with the fleet captan to verify that max measurement for the fleet races.
I figured otherwise, it was an anything goes. The 10-18 seemed a bit big, where as the 8-14 seemed a bit more appropriate to my thinking. A 9-16 would be best! ie 140% of 11.5 = 16.1.
Then assuming that the 140 is based on a 150-155, a smaller headsail, one would want to be say 10'ish % smaller pole, so my 110 would be about 11'...... and the 16' would work for my 80% of max AS sail availible too.
Thinking on this, I may remembering 70-80% of the overall LP too, which would be about 140% of J on a 150-155 LP genoa too! It could be one of those I am not remembering ALL of the facts correctly.
Thanks for replys.
Marty
Old 06-11-2007
GeorgeB GeorgeB is offline
GeorgeB is on a distinguished road
Whisker Poles
Interesting that your local YRA has a PHRF rule dictating whisker pole lengths. Our Northern California YRA has no such restriction. However, my one design class rule does have a restriction and it is 16’ 9” which represents 80% of our max headsail LP of 155%. Our rules further dictate that the pole must be clearly marked at Its longest “legal” length. My personal experience has been there is a point where you get a diminishing return when extending the pole past a certain distance. I do not go beyond 90% of LP. I know others who don’t go beyond the foot dimension of the sail their using. No matter what, it is illegal (RRS – Equipment section) to use a whisker (or any pole for that matter) in conjunction with an asymmetric. If you are having trouble keeping the kite inflated, try using smaller diameter sheets (a.k.a. “dental floss) or stripping the covers off of the first 10-20’ of sheet. (I’m assuming you already have a .5 oz kite, if you have a heavier one, sell it and get the half ouncer.)
Old 06-11-2007
midlifesailor midlifesailor is offline
midlifesailor is on a distinguished road
According to the link below, PHRF of the Chesapeake limits whisker pole length to "J" for non spinaker class. If the pole is adjustable, a red color must be visable when extended beyond the rated length.
It seems the max allowed length varies a great deal depending on where you are racing.
http://www.phrfchesbay.com/esspec2.pdf
Old 06-11-2007
Whisker pole size
PHRF Southern California is quite specific. Limits of poles without penalty are: spinnaker=J, extended bow pole (sprit boats)=manufacturers length, whisker pole=140% of J.
If you are using a whisker pole as a spinnaker pole it must be fixed to a max length = J.
Get the 8-14 or the 9-16 and you have all the bases covered!
Old 06-11-2007
T34C's Avatar
T34C T34C is offline
EqualOpportunityOffender
T34C has a spectacular aura aboutT34C has a spectacular aura about
Do they regulate where you attach the pole to the boat? Pretty easy to get a couple extra feet out of the pole moving it to the rail from the mast.
If you're new to Sailnet Forums...please, pull my finger. (And skip SD's post! )
Old 06-11-2007
tenuki's Avatar
tenuki tenuki is offline
Helms ALee!
tenuki will become famous soon enough
use the cheaper boathooksailorcombo pole, no class limit that I know of for that.
(props to From the Dock for this image)
Old 06-11-2007
I wonder if my class rules are using So Cal’s PHRF as a guideline as the two measurements are the same? In any case, length up here isn’t much of a problem in so much that 140 headsails carry a PHRF penalty. Besides, why invoke a penalty when a code sail will do the same job? In regards to my comment about the “no pole on asymmetrics” that is to say no pole on the clew/sheet end. Spirit poles can be used but require a ratings adjustment (at least here in Nor Cal). RRS state that spars (poles) must be attached to the mast. And a ruling in one memorable protest appeal it was determined that a “crew member is not a pole” and cannot be used to hold out a clew with a boathook. You can, however, hold the clew with your hand as long as you are not violating the “crew outside the life lines” rules. Needless to say you hear a lot of funny stuff when you are on RC.
Display Modes
vB code is On
Spinnaker vs Whisker Pole jr438234606 Gear & Maintenance 2 04-09-2007 08:46 PM
whisker pole ?????? mangomike General Discussion (sailing related) 4 10-01-2006 08:05 PM
Whisker Pole vs Cruising Spinnaker r2straebel Gear & Maintenance 5 01-24-2002 08:25 AM
Using a Whisker Pole Dan Dickison Racing Articles 0 09-04-2001 08:00 PM
Using A Whisker Pole Dan Dickison Learning to Sail Articles 0 04-23-2001 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
