06-11-2007
Full-time Cruiser
24V options for windlass/thruster
I want to convert the "manual" paralleling system for the 24V bow thruster for my boat. Right now, the windlass is 12V, but I'd like to upgrade it to 24V operation. A previous owner rigged a panel that will series-connect one of the house banks to get 24V. It's currently a safety hazard - you have to remember to switch to 24V before you use the bow thruster, and you have to remember to switch it back after.
I would have gone to a full 24V system for the entire boat, but it would require changing out all the 12V equipment. So I'm looking at two options: - Install a dedicated 24V bank, and keep it charged with a with a relatively inexpensive 120Vac/24Vdc charger. The drawback would be we'd have power the charger from the genset or an inverter drawing off the main house bank. Doable.
- Make up a 12V/24V paralleling relay and trigger it from either the breaker for the windlass and thruster, or get fancy and trigger it from the windlass footswitches and the thruster control.
I searched the forums and haven't found a comprehensive howto or description of #2. Seems easy enough, but can anyone comment from experience on either of these two options, and point me to a reference site?
BTW: I'm re-engineering the 12Vdc power system on the boat - dedicated engine starting battery and genset starting battery, and am looking at ~800Ah of Trojan 6V AGMs for the house bank. I do have space for two grp 27/31 12V batteries up front if I do go the dedicated 24V route. I'm still trying to decide on a charging system - the new Westerbeke/Century 120hp diesel has a beefed up 190Ah alternator with external regulator, but I'm having trouble finding an AC marine charger that outputs in the 200Adc range. I guess I could go the modular route like an AmplePower system - any recommendations? I have an electrical engineering background, so start with details if you can.
Thanks!
Cap'n Jon
KB1HTW
S/V Beausoleil
1979 Formosa 51 Ketch
Homeport: Marblehead, MA USA
