06-29-2007
I have a Honda 9.9 HP 4 stroke long-shaft from 1985 (BF100) and a Mercury 9.9 two-stroke short shaft from 1999 (came with the boat). I would say although the Mercury is lighter by 15 lbs. or so and arguably gets a heavy 10' 2" RIB on the plane a tad faster, it runs noticeably hotter and certainly louder than the Honda. The Honda, even this 22 year old one, is about the quietest outboard I've heard in this range. It's also very torque-y, which means I can and have used it to push 10,000 lbs. of motor-sick sailboat at 4 knots or better...when on a RIB lashed to the side.
That being said, I have to rebuild the carb because I neglected to run it dry one year and cacked it up. I bought the Clymer shop manual and will have it running again shortly, but you can't abuse it in terms of layup. If you maintain it, however, my experience is that you can run it full-bore all day if you want.
This old model is why I'm considering getting the Honda 2 HP 4-stroke air-cooled, because I think they are built well.
