06-12-2007
Best Looking Moderator
You can start by rebuilding the pump. Depending on the model, this is not that tough. However, in some cases, it is cheaper just to replace the whole thing, bowl and all.
If you can pump wet, I cannot see why you cannot pump dry. Sounds like a valve sticking. I will warn you, on some heads, the lever to switch to dry bowl is tricky and has to be all the way up (or back). We have a Wilcox and it is like this. It can look like it is up, but it is juuuussssst out of dry bowl. The effect is when you push down on the handle, it hardly moves like there is a whole lot of pressure behind it. It that is your symptom, perhaps it is as easy as the lever is not quite in the right position. Try jiggling it as you push down to see if that helps. If not, rebuild or replace is my guess.
Hope that helps. Nothing wears on a skipper like a crappy crapper. (smile)
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
