06-15-2007
If they are stainless, the paint isn't helping them any. Stainless steel needs oxygen to work properly. If they were painted, and the prep job wasn't perfect, that likely contributed to them rusting after a while. What's worse is that it may have hidden the corrosion from casual inspection. Leaving the bolts uncoated is probably best.
