Blogs
User Name
Old 02-18-2002
NateWing NateWing is offline
NateWing is on a distinguished road
Sandblasting
I would like to open the discussion regarding sand blasting yet once again. I have read many conflicting opinions.
For purposes of removing bottom paint and clearing out numerous small gelcoat blisters I am looking for recommendations or warnings based on first hand experiences.
thanks,
Old 02-18-2002
Pangaea Pangaea is offline
Pangaea is on a distinguished road
Sandblasting
Nate,
With mabye twenty or so of this kind of job under my belt, mabey I can help.
First of all when you corn cob blast your under body not only do you clean out the blisters, but you also open up all of those
voids left by the manafacturer which have gotten worse depending on the age of your boat. h
Hopefully the blisters are only
the surface type.If they are in the layers of the laminate, it''s more serious, but repairable. They have to be ground out and repaired seperatly.
After blasting and sanding scrub the under body with trisodiumphosphate.
Let the boat dry for as long as posible,
weeks to months,the longer the better.
You want the bottom to be dry when you start filling blisters and voids. Fill with an epoxy thickened with cabosil. Do not us a
thickener like microboloons or anything that can absorb water. When spreading
the epoxy, take it easy, and remember that it is not easy to sand. So, fair the hull
and apply at least six coats of epoxy barrier coat. Ten would be
more like it.
Let me say, if your blister problem is more than light, this may not be the perfect solution.
good-luck.
Dennis L.
Display Modes
vB code is On
Sandblasting alternative? lee_1999 Gear & Maintenance 6 05-03-2002 05:48 AM
Sandblasting? michaelhalliday General Discussion (sailing related) 5 03-23-2001 04:29 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
