Old 06-17-2007
mwrohde is on a distinguished road
'nother rudder question
Cal 3-27, wheel steering. The rudder post passes through the hull through a fiberglass tower. On the side of this tower or tube is a zirc fitting. I assume, based on the presence of this zirc fitting, that I should apply grease.
The question is what kind and how much?
Thanks
Old 06-18-2007
Bumping back up - hoping one more pass through someone will have an answer . . .
Old 06-18-2007
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
Any chance of a picture?
Old 06-18-2007
I was afraid someone would ask that. My camera sucks so bad it won't capture a picture in the engine room.
Picture this. It looks just like the tower Richard Dreyfuss made out of his mashed potatoes in "Close Encounters", except with a zirc fitting on the side. It's molded fiberglass, about 10" tall. At the base it's about 4" or 5" in diameter. At the top it's about 3" in diameter.
If that stunning description is lacking I'll grab somebody's camera and snap a pic.
Old 06-18-2007
Idiens's Avatar
Larus Marinus
OK zirc = zerk. The usual suggestion on the tractor forum is to pump grease in until you see it coming out somewhere. It might work for rudders too, but probably only on the hard, as the grease may choose the route down instead of up. I would squirt 5 fives, waggle the rudder and maybe squirt five more. If your using a good grease gun and after a couple of squirts it goes hard (not the first one, its breaking the seal on the zerk) stop pumping or you may break a shaft seal somewhere.
Old 06-18-2007
Cruisingdad's Avatar
Best Looking Moderator
In general, squirt until you see it. However, some fittings are sealed and overgreasing will blow the seal. Don't ask me how I know... I SAID DONT ASK.
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 06-18-2007
Any particular kind of grease?
Sorry about my spelling. I thought I'd seen z-i-r-c. Even googled it and got some hits. So, away I went.
I'd be surprised if this is a sealed fitting. The boat is 24 years old. Seems to me sealed chassis in cars came much later than that.
Thanks for the help.
Old 06-18-2007
CD-
How do you know...
Old 06-18-2007
Goodnewsboy is on a distinguished road
Use a waterproof grease that you can get at the auto parts store. It is commonly used in boat trailer wheel bearings.
Zerk fittings are not a good idea in this application in my opinion. They invite overpressuring the grease containment. Most manual grease guns can generate 5-10 THOUSAND pounds (psi) of pressure. Much safer to use a grease cup if you have any say in the matter. You just give the cup a turn or two a couple of times a season and the problem is taken care of.
Here's a picture of a grease cup:
Grease Cups
Here's another device that has pressure relief:
GUN-fil® LUBRICATORS : Lube Devices
Old 06-18-2007
Thanks, folks. I'll get some grease, soon. Zerk fitting is already installed. It's been there 24 years I expect.
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 01:11 PM
Emergency Steering John Kretschmer Seamanship Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Cruising Articles 0 03-08-2002 07:00 PM
Rudder Problems Mark Matthews Gear and Maintenance Articles 0 02-13-2002 07:00 PM
