Glassed in keel bolts - Page 2 - SailNet Community
post #11 of 17 Old 06-19-2007
Ugh... you need someone with long arms and small hands to fix this problem... A chimpanzee would be ideal... What the hell were they thinking?
Also, why glass over the bolts, if they are inside the boat.... if you ever have to tighten them, you have to get rid of the glass. I think the real problem is that the hull-keel join isn't tightly sealed, as the bolts have loosened or something has compressed—and that is why you're having such a tough time sealing the area.
What I would recommend is that you un-encapsulate the damn bolts and tighten up on them after cleaning, sanding and re-bedding the hull-keel joint with 3m 5200 or a good polysulfide sealant. Then, after tightening up the bolts, I would recommend you glass over the hull-keel join on the outside of the boat. If it leaks after that, the water is coming from someplace else...
sailingdog is offline
post #12 of 17 Old 06-19-2007 Thread Starter
Zingaro
mpraca's Avatar
Originally Posted by Gene T
It looks like the only place for water to get into the keel joint would be at the top of the keel to the hull bottom, or about 1 inch below the opening in the sump. Sealing there should be sufficient to prevent any water from getting in there. I don't understand the cardboard thing. There shouldn't be anything like that. Whatever it is it should be removed.
The cardboard is enveloping the sump box around the sides and bottom, and can be seen when I grind out the the filler that was used to fair the only side that is open. There is less than 1/4" space between the sump box and the metal round it which is filled with the cardboard. I agree that the cardboard should be removed but it is impossible. I was hoping to hear from anybody that has seen this before, or some ideas to get rid of moisture in the cardboard before sealing the whole thing again.
I'm trying to get ideas that I will try next haulout. Thanks for everyone's comments.
mpraca is offline
post #13 of 17 Old 06-19-2007
Gene T's Avatar
I am having a difficult time understanding the setup. Is the sump bigger than the opening? It doesn't look that way from the picture. From what you are describing with the cardboard it could be used to wick moisture out of an area intended to be dry. But it will mildew and stink eventually. If it were me I would call Erik Stromberg and find out what is supposed to be going on in there. estromberg@jeanneauamerica.com
JEANNEAU AMERICA, Inc.
105 Eastern Avenue, Suite 202 Annapolis, MD 21403 USA
tel: 1-410-280-9400 fax: 1-410-280-9401
I'm wondering now if the cardboard is just used as filler/insulation between the cutout in the keel and the fiberglass sump.
Gene T is offline
post #14 of 17 Old 06-20-2007
blt2ski's Avatar
Looks like what is going on with my 22 yr old Arcadia. The yard I am at, says this is "common" if you will. My bolts are encased too.
You may want to go to www.jeanneau-owners.com and post at that forum, and see if others are having the same issue. I did not have this issue 2 yrs ago when I bought the boat. Currently the boat will be put back in tomorrow, after the keel has been cleaned off, new epoxy and sealent ie 5200 along the keel to hull are you have the same issue with. This should be good for some 6-8 yrs. Or at least I have been told.
Marty
blt2ski is offline
post #15 of 17 Old 06-20-2007
Here .. Pull this
I suspect that the cardboard is meant to be removed, but that someone at the yard missed it when the boat was shipped. It was probably put in there as a makeshift moulding form, with the idea that it would be taken out, and that any vestiges could be easily clead off with water.
Sailormann is offline
post #16 of 17 Old 06-20-2007 Thread Starter
Zingaro
mpraca's Avatar
Thanks! that's good advice. I just wanted the boat back in the water so I didn't do a lot of research at the time. Now I have a year or two to prepare for the next haulout.
It looked like the cardboard was just like insulation but it is impossible to dry it properly and it will trap moisture that gets sealed in.
mpraca is offline
post #17 of 17 Old 06-20-2007 Thread Starter
Zingaro
mpraca's Avatar
Let me clarify. The carboard is trapped between the keel and the bilge box. It is sealed inside and the only reason I found out about it is that I had water leaking in through the hull/keel joint and I had to grind the epoxy out as I followed the moisture. Then I tried to clean up the space around the boxlike sump (bilge) that is encased into the keel cavity. It was impossible to remove the cardboard so I dried it as much as I could by soaking with alcohol and sealed it in again with epoxy.
mpraca is offline
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Bolts Repair/replacement chartscharts Gear & Maintenance 11 08-07-2006 03:53 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
