06-19-2007
IMHO, draining the fresh water tanks into the bilge is just a PITA and a bad idea. The pressure system pump should be able to handle the load of getting rid of most of the water from the system pretty easily—after all, that is what it is designed to do. It might be wise not to run it for one long burst, but in several shorter ones.
A siphon can deal with what is remaining after the pressure system has used all the water it can.
