Old 06-20-2007
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Wheel and Binnacle to Tiller?
Just a general, non-maker-, non-model-specific query: Say a boat has a wheel and binnacle and you wanted to deep-six 'em in favour of a tiller: Won't there be a large-ish hole where something from the wheel mechanism goes through the sole and a couple or so bolt holes, or whatever is used to fasten the binnacle down? What do you do about those?
Somehow I think just throwin' a small throw rug over 'em ain't gonna cut it
Thanks,
Jim
Old 06-20-2007
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
You could turn that hole into an inspection port for that section of the boat. With a custom made port cover.
A FPG boat? Glass that hole over and blend it in to where it matches the rest of the deck sole of the cockpit.
An extra large cockpit drain??
Have plaque marking it as the place where you stuff all of the money you are spending on the boat?
Okay the last two are from a wry sense of humor. And the last one bears a truth that is undeniable.
Old 06-20-2007
The inspection hatch isn't such a bad idea... and glassing over the area isn't all that difficult a repair to do yourself.
Old 06-20-2007
tommyt is on a distinguished road
A whole lot easier to buy one with a tiller. Lots of them out there.
I have heard on people converting from tiller to wheel. I think this is the first I have heard of the reverse. Interesting.
Old 06-20-2007
A friend has an Ericson 33 that has been converted back to tiller steering. They have a circular plate cover where the pedestal used to be, and you can still see the bolts for the under-deck sheaves (and the quadrant is still on the rudder shaft).
Other than a mild tripping hazard, it's fine. One has to get used to the bump in the cockpit floor.
On the plus side it's going to be much easier for the next owner to re convert if desired! On the down side he's packing some extra weight in gear that he's not using... not a big dealf or a cruiser, but perhaps worrisome to a hard core racer.
Old 06-20-2007
Valiente's Avatar
There's a variety of square and circular inspection ports from Davis, Beckson, etc. You could go one better and glass in a squared off or cylindrical bucket to hold a few beverages or a bottle of wine. Just make sure the deck cover is gasketed and lockable. Even in my pilothouse, I'm going to replace the existing "loose" wooden hatch in the pilothouse floor with an aluminum gasketed hatch on a gas strut (I get tired of hauling the existing four by five foor slab out!)
Speaking of which, I've seen plenty of smaller boats with tiller steering (through the aft coaming) where the owners have made part or all of the cockpit sole removable in order to get access to the rear of the engine, to service the exhaust system or just to extend stowage. Even if you only had 12 inches of clearance, you could stash fenders, brooms, spare boathooks, inflatables, and loads of line below the sole without much trouble, as long as you separated the stowage areas from anything hot or moving.
Hey, Google found me a nice example:
Pearson Triton #381 Glissando | Aluminum Cockpit Access Hatch
Old 06-20-2007
Thanks Valiente.. that might be a good solution for another project I have in mind.
Old 06-20-2007
Buy gun...take gun home.....load gun......unlock gun.....put gun in mouth......press trigger......
Old 06-20-2007
Here .. Pull this
Sailormann will become famous soon enough
If you do end up with a few bumps and protuberances there, you can always put in a natty-looking cockpit floor grate...
Old 06-21-2007
SEMIJim's Avatar
Thanks for the feedback and suggestions, guys . I just called the seller and told him we'd decided to take a pass. I don't see the sense in buying a boat with a wheel, knowing we almost certainly won't want a wheel on a 28' boat.
KISS? or ... why a wheel? jbarros General Discussion (sailing related) 48 12-15-2008 04:17 PM
Wheel to Tiller TADIAS General Discussion (sailing related) 3 06-16-2005 04:20 PM
Wheel to Tiller TADIAS Gear & Maintenance 2 06-12-2005 06:48 PM
What Would You Buy For 70 Grand Dav-O Boat Review and Purchase Forum 22 03-26-2002 09:11 PM
