Old 06-20-2007
sailhog has a spectacular aura about sailhog has a spectacular aura about
bilge pump trouble
My Jabsco bilge pump has finally stopped moving water, although the motor still runs. Does the learned panel know of any common problems and easy fixes, or do I refrain from being a cheap ass for a change and go buy a replacement?
Old 06-20-2007
ChicagoNewport27's Avatar
Purveyor of Fine Ideas
ChicagoNewport27 is on a distinguished road
Depends on the size/cost of the pump. The cheaper pumps dont have serviceable parts, if I recall correctly. The more expensive ones will let you at least change out the impeller (which is what you need, most likely). See if you can take it apart and inspect the impeller. If you can't then chuck it and buy a new one.
Or, to play devil's advocate...
Ask yourself this: If your toaster breaks, do you fix it, or toss it and buy a new one? Most of us would answer that they just buy a new one, because they're only $30. What's your time worth?
Old 06-20-2007
FrankLanger is on a distinguished road
If the motor is still running and sounding fine, it's a relatively easy and much cheaper step to buy a new "service kit" which should consist of an impellor and O rings. I just replaced mine (also a Jabsco) this past weekend, and I'm a bad mechanic and didn't have any trouble with it--just a few screws to take off the plate, pull out the impellor with needle nose pliars, add grease to the new one, replace the old O ring with the new one, and put it back together. It took well under an hour, and cost of the kit was $29.95 compared to the same pump new at $229.99. The chandlery had both in stock.
My motor was also still working, but no water was being pumped, and the new impellor fixed it so it's working perfectly.
Good luck!
Frank.
Old 06-20-2007
Cruisingdad's Avatar
Best Looking Moderator
It is possible it is not the pump. Many bilge pumps had check valves just off the exit. It will ussually be a brass cylinder. These are prone to getting clogged and stopping up. Also, I have found that without some water on the exit port, some bilge pums tend to not do anything but hum.
TO check it, simply pull of the exit hose, make sure there is water in there, and turn it on with the bottom of the pump in the water too. IF it moves water, it may very well not be your pump. If it does not, I always replace. It is very easy to replace it. Try to find the same one if possible so you do not have to remove and replace the mount.
The bilge pump is one of the most critical pieces of safety equipment on the boat. I don't fool around with it.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 06-20-2007
christyleigh's Avatar
christyleigh is on a distinguished road
The most common problem and easiest to fix is a clog of the screen many people have on the bilge end of the hose or simply the hose itself. If you have not pulled off and checked the input hose that is where I would start. The output hose is a less likely suspect but I would check that before taking the pump apart. There is also the possibility that the P.O. added an backflow valve that could be clogged.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
Old 06-20-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
sailhog must have some huge cajones to stay with his computer, while his boat is sitting at the marina . . . with no bilge pump!
True Blue . . .
sold the Nauticat
Old 06-20-2007
TB, the cojones are larger than the brain... She's got new seacocks and I keep them all closed, so I'm thinking she'll stay afloat for a few more hours. I'm going to take Stan's advice and start with the hoses, and if that isn't it, I'll take a quick look inside the pump. It's a $125 unit, and I don't want to waste a pile of time. Thanks Chicago, thanks Frank. I appreciate the thoughtful replies. It's helpful to have people like Cruisingdad and True Blue scare the **** out of you. I had the wife and kids out on Port Royal Sound yesterday. We were bouncing through waves that were big enough to send salt spray through the forward hatch. The family had their feet over the rails, getting wet, having a blast. The bilge pump was working when we left the dock, but it wasn't as productive as usual. I'm a nervous ninny when the kids are on board, and I've always got worst-case scenarios running through my mind when something isn't quite right. Anyway, you guys are the best.
Thanks,
Sailhog
Old 06-20-2007
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
You must have used it to drain your water tanks uh?
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Devising a Better Bilge Pump Don Casey Seamanship Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 08:00 PM
