Help identifying a propeller - SailNet Community
post #1 of 2 Old 06-20-2007 Thread Starter
all these confusing ropes
Boatyard took care of the bottom painting for me; boat is located far away in the carribean and is now in the water. They did not have the zinc in stock, but luckily someone snapped a photo of the prop. I can see the word "Italy" stamped on the prop but cannot figure out who the manufacturer is. I want to get the replacement zinc, bring it with me and put it on. Any ideas on who the manufacturer might be? I think its a maxiprop. http://www.pyiinc.com/images/pdf/max...structions.pdf
Thank you.
mystery prop
dohenyboy is offline
post #2 of 2 Old 06-21-2007
I don't discuss my member
Fstbttms's Avatar
You are correct, it is a 3-blade "Classic" model Max Prop (not "Maxi".) And that's an old one, for sure. If you tell me the shaft diameter I can tell you which size Max Prop zinc you need.
Fstbttms is offline
Propeller Pitch camaraderie Gear & Maintenance 3 03-25-2005 07:46 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Choosing a Propeller Mark Matthews Gear and Maintenance Articles 0 07-24-2002 08:00 PM
Propeller Problems Mark Matthews Gear and Maintenance Articles 0 05-27-2002 08:00 PM
Check the Propeller Tom Wood Gear and Maintenance Articles 0 02-25-1999 07:00 PM
